Tuttnauer - 66 Mid Range Series
by Tuttnauer
66 Laboratory Autoclave Mid-Range Series
The Horizontal 66 Autoclave Series of autoclaves is designed to accommodate chamber volumes ranging in size from 340 to 600 liters and for the proccesing needs of various load configurations. The autoclave sterilizers are designed and manufactured in a state-of-the-art facility in compliance with strict international standards to ensure safe re-use of sterilized equipment. Tuttnauer also builds customized autoclave configurations to adapt to a customer’s site layout. The Horizontal 66 autoclave series is designed to cover a large field of applications for hospitals, CSSD and medical centers.
-wperez
4 years ago
Manual
I am trying to get the Calibration manual for the 66120 autoclave.Reply
[list]        Door Safety           [*] A safety device prevents the operator from opening the door when chamber is pressurized           [*] Steam is not allowed into the chamber when the door is open           [*] A cycle will not start if the door is open or not properly closed           [*] The door cannot open until chamber pressure reaches room pressure           [*] Sliding Door Safety -The sliding door progress will automatically stop if an obstruction is detected           [*] Double Door Safety – interlocks prevent both doors from being opened simultaneously    General Safety Features:           [*] Double Independent Monitoring: The combined digital and mechanical monitoring provides a cross reference and guarantees accurate results. The operator has two independent means to monitor temperature and pressure.  [*] Safety Valves: Both the chamber and the jacket are equipped with safety valves –if the pressure exceeds the allowed limit the safety valves will discharge.  [*] Built-in Steam Generator Safety: A water level monitoring system maintains a constant water level and ensures safe operation of the heaters.  [*] Emergency Shut-Off: Easily accessible emergency switches for immediate and safe shut down of the sterilizer.  [/list]
SERIES MODELS
Tuttnauer - 66120
Tuttnauer - 6666137
Tuttnauer - 6671130
Tuttnauer - 6671162
Tuttnauer - 6690
