Leica Microsystems - M400 E
Surgical microscope for ENT surgeryCompact and stable, the Leica M400 E surgical microscope series combines the convenience of a quick operating room set-up with a high-quality optical system. The superior, sharp contrast image and large depth of field are hallmarks of the Leica M400 E. The swing arm’s long reach allows the stand to be positioned farther from the operative site to provide ample space around the operating table and the patient. The new ergonomically designed handle gives the surgeon fast, precise and effortless positioning with one hand.
FORUMSView All (5)
0Replies9 months ago | Light Boost? Doing a little service on this M400 E and came across this setting. When turned to "11" not any difference was noticed in brightness. Does anyone know what this feature is, or is it possibly not working? Equipment: Leica M400 E Reply |
1Reply2 years ago | base f20 Dear forum members! I would appreciate if I could get a service manual or drawings of: Base f20 of LEICA M400 E. The microscope base weight was released. This can be helpful. Regards Jean-MarcReply |
0Replies9 years ago | Cordless pedal assembly Constantly having a "dead battery" issue, non-functioning pedal. Checked batteries, have been up to spec (1.49v) Suspect a receiver issue, not a bad pedal. anyone have this problem? Thanks ken Reply |
- Leica Microsystems’ crisp optics provide outstanding image quality - higher contrast and higher resolution, more detail is visible resulting in better surgery
- The simple balancing system, allows the Leica M400 E, with accessories, to be brought into a state of equilibrium with only a few adjustment
- The integrated halogen illuminator emits a coaxial light beam that penetrates even the narrowest cavities, illuminating the field of view brightly and uniformly.
Field of view | 33 to 132 mm |
Focusing | Manual |
Magnification Range | 1.5× – 40× with 10× eyepieces |
Microscope Objectives: Fixed focal lengths from f = 100 mm up to f = 400 mm, fine focusing lenses with f = 250 mm, 275 mm and 300 mm Eyepieces: Wide-field eyepieces for spectacle wearers 10× and 12.5×, Dioptric setting +/ 5 with adjustable eye cup Illumination: integrated koaxial halogene illumination 12V/50W with quick lamp changer, optional with light intensifier
