Amerex Instruments - HG Series
Hirayama HG-Series Autoclaves with an Innovative Feature...Just Press a Button to Automatically Open the Lid, or Close and Lock It.
0Replies11 years ago | Hirayama HG-50 Autoclave Just want to clarify if the lid can be easily misaligned if it was accidentally closed manually? Can it cause problem in reaching the set point temperature? can it cause molding of the sterilzed bottle? Reply |
[list] [*] Automatic lid opening button replaces a foot pedal. [*] Automatic lid closing button closes and locks lid conveniently and safely. [*] New body design with larger diameter and shorter height. [*] Safety interlock senses pressure and temperature and prevents lid from opening when the chamber is pressurized, temperature is too high, and also during a cycle. [*] Programmable auto-start for running a cycle up to 99 hours later. [*] Efficient 15-liter steam condenser eliminates steam exhaust into the lab. [*] Over-flow lamp indicates that the drain bottle is full and ready to be emptied. [*] Built-in fan for faster post-sterilization cooling and shorter completion time. [*] Selectable rate of steam venting after sterilization. [*] Programmable time for air removal before sterilization. [*] Large control and display panel improves functionality and shows the progress of the sterilization cycle. [/list]
