STERIS - AMSCO Evolution Medium
by STERIS
The difference in Evolution's controls is obvious, even from across the room. The end results - improvements in efficiency and productivity - will be just as clear. A dramatic redesign of Evolution's controls and displays includes crystal clear, high-resolution graphics and an Ethernet-enabled PC control. With one touch, operators can begin to learn it and put the control to work. Look forward to Evolutionary differences in your Sterile Processing Department with greater throughput, reduced downtime and improved efficiency.
An Evolutionary advance in form and function. Open the door and look inside. This is where Amsco Evolution's unique shape really shines, providing consistent quality and reliability beyond other chamber designs. Evolution's unique, inherently strong round or elliptical form promotes even pressure and heat distribution within the chamber. It is also inherently efficient, with a fully jacketed chamber that minimizes condensation and maintains quality through every cycle. The 26"- wide chamber opening facilitates easy loading, and processes each load with minimal steam consumption. With a unique form, which improves function and helps to reduce operating costs over time, Evolution is an advance worth looking into.
0Replies7 years ago | Maintenance Manual in PDF I need help. Can anyone kindly help me get a PDF of Maintenance Manual for AMSCO Evolution Medium Sterilizers (P764333-449/452/450/454) Reply |
