STERIS - AMSCO Century
Amsco Century Medium Steam Sterilizers are equipped with the latest features in both state-of-the-art technology and ease of use.Two configurations are available for sterilization of heat and moisture stable materials used in healthcare facilities: Prevacuum - designed for fast, efficient sterilization of heat- and moisture stable materials. Prevacuum configuration sterilizers are equipped with prevacuum, gravity, liquid, leak test, and daily air removal (Bowie-Dick) test cycles. Steam Flush Pressure Pulse (SFPP) - designed for fast, efficient sterilization of heat and moisture stable materials. This configuration sterilizer uses the Steam Flush Pressure Pulse cycle, which features an above-atmospheric pressure level conditioning phase. SFPP sterilizers are equipped with SFPP, WRAP/ SFPP, prevacuum, gravity, liquid, leak test, and daily air removal (Bowie-Dick) test cycles.
FORUMSView All (4)
0Replies7 years ago | Service manuale of Steris Amesco century 540 L & 430 L I'm interested in get the service manual of a Steris Amsco Century 540 L & 430 L Steam Sterilizer. If anyone have it it will be greatfull to send it to my e-mail atafa1967@gmail.com Reply |
0Replies7 years ago | Taking too long to charge Machine is showing error message " taking too long to charge" while doing bowie-dick test. I checked the machine thoroughly but couldn't find any leakage. Also the pressure was also regulated using "pressure regulation valve" but all in vain. Can anyone help me out here?Reply |
1Reply7 years ago | Lock Switch Failure Have a V-160H getting a Lock Switch Failure LS5. I was able to get it to work after several tries. Is this a replace switch, adjustment or typically software repair?Reply |
State-of-the-Art Control Systems
- Continuous cycle monitoring and control
- User-friendly color touch screen with a large, easy-to-read display, complete messages (no codes), help screens, programming prompts, and single-button operation
- Continuous service diagnostics
- Clear, easy-to-read, non-fading impact printer
Rugged Construction for Long-Term Use
- Chambers, jackets, and doors constructed of 316L stainless steel
- Fully jacketed chambers for even temperature distribution
Easy Servicing and Maintenance
- Modularized piping with fewer component connections to reduce and simplify maintenance
- Complete message service diagnostics (no codes) provided by the Century Stage IV Control system
- Unique door seal that never needs lubrication
- Emergency manual exhaust that allows the operator to vent the chamber and save the product in case of power outage
