STERIS - AMSCO Century
by STERIS
Two configurations are available for sterilization of heat and moisture stable materials used in healthcare facilities: Prevacuum - designed for fast, efficient sterilization of heat- and moisture stable materials. Prevacuum configuration sterilizers are equipped with prevacuum, gravity, liquid, leak test, and daily air removal (Bowie-Dick) test cycles. Steam Flush Pressure Pulse (SFPP) - designed for fast, efficient sterilization of heat and moisture stable materials. This configuration sterilizer uses the Steam Flush Pressure Pulse cycle, which features an above-atmospheric pressure level conditioning phase. SFPP sterilizers are equipped with SFPP, WRAP/ SFPP, prevacuum, gravity, liquid, leak test, and daily air removal (Bowie-Dick) test cycles.
0Replies8 months ago | Reaching sterilization temperature but not going into sterilize mode I have a 26 x 26 medium Amsco Century that will reach sterilization temperature but won't go into sterilize mode to complete the cycle. I can't figure out the reason. Any theories or suggestions for me? Equipment: Amsco Century Reply |
0Replies8 years ago | Service manuale of Steris Amesco century 540 L & 430 L I'm interested in get the service manual of a Steris Amsco Century 540 L & 430 L Steam Sterilizer. If anyone have it it will be greatfull to send it to my e-mail atafa1967@gmail.com Reply |
0Replies8 years ago | Taking too long to charge Machine is showing error message " taking too long to charge" while doing bowie-dick test. I checked the machine thoroughly but couldn't find any leakage. Also the pressure was also regulated using "pressure regulation valve" but all in vain. Can anyone help me out here?Reply |
State-of-the-Art Control Systems
Rugged Construction for Long-Term Use
Easy Servicing and Maintenance
