Andersen Products - Anprolene AN74j
by Andersen Products
The High Capactiy Anprolene Option
The Anprolene Professional Series was created for facilities that use their sterilizer intensively. The AN-74J ("the Jumbo")features all stainless steel construction for durability. The Jumbo offers our deepest cabinet for longer instruments, and a wider door (17") for larger flexible scopes that cannot be coiled tightly.                                With its large capacity and all-stainless steel construction, the Jumbo was designed for larger instruments, rigid scopes, and heavy use. The Professional Series still offers the most gentle 100% EtO sterilization cycle on the market: room temperature sterilization (minimum 68o F), no steam injection, no deep vacuum, and only 17.5 grams of gas.                                This is the most robust and versatile low temperature sterilizer available, now featuring a number of important improvements. They include: more powerful ventilation and purge pumps, unique active aeration system, digital display tracks cycle progress, temperature sensor monitors room conditions during each cycle, microprocessor monitors cycle and automatically restores system in case of power failure.
-Biomed Plus
7 years ago
PM & Parts
Can anyone give advice on performing a PM on one of these units? What about parts? Does the tubing have to be of a certain kind?Reply
-JV
7 years ago
Are parts avaiable ?
Does anyone have a PM procedure?Reply
[list]                [*] Unmatched Sterilization Flexibility - Anprolene's 100% EtOsystem sterilizes at room temperature without external vacuum lines or steam generator. Protects your most delicate instruments, electronics, drills, fiber optics, and plastic or rubber items... Sterilize most any item with the exception of food, drugs or liquids with Anprolene.    [*] Sterilization and Aeration in the same cabinet - The Anprolene System utilizes an advanced purge system that aerates products for two hours at the end of the cycle. Active aeration continues indefinitely until products are removed, and the cycle is ended.    [*] Proven Reliability - The choice of healthcare professionals for over 40 years, Anprolene is used in over 5,000 facilities worldwide.    [*] Unique Load Size Flexibility - The Anprolene system uses unique plastic sterilization liner bags and individual gas ampoules. We offer two different sizes of bag/ampoule combinations to match the size of your sterilization load. You never use more gas than you have to!                [/list]
Chamber Width17.87 in
Height20 in
Chamber Height12.5 in
Length 31 in
OrientationBenchtop
Weight85 lbs
Chamber Depth29.25 in
Width18 in
