Andersen Products - Anprolene AN2000
by Andersen Products
The AN-2000 features all metal construction, including a double walled design with a powder coated exterior and stainless steel interior. Wider door (14") is designed for larger procedure trays, coiled flexible scopes and bulky instruments. The Professional Series still offers the most gentle 100% EtO sterilization cycle on the market: room temperature sterilization (minimum 68o F), no steam injection, no deep vacuum, and only 17.5 grams of gas. This is the most robust and versatile low temperature sterilizer available! Anprolene sterilizers now features a number of important improvements. They include: more powerful ventilation and purge pumps, unique active aeration system, digital display tracks cycle progress, temperature sensor monitors room conditions during each cycle, microprocessor monitors cycle and automatically restores system in case of power failure.
1Reply6 years ago | Service Manual Have a local customer with one of these. Does anyone happen to know of any service manual information out there?Reply |
[list] [*] Unmatched Sterilization Flexibility - Anprolene's 100% EtOsystem sterilizes at room temperature without external vacuum lines or steam generator. Protects your most delicate instruments, electronics, drills, fiber optics, cameras, and plastic or rubber items... Sterilize most any item with the exception of food, drugs or liquids with Anprolene. [*] Sterilization and Aeration in the same cabinet - An advanced purge system aerates products for two hours at the end of the cycle. Active aeration continues indefinitely until products are removed, and the cycle is ended. [*] Proven Reliability - Anprolene has been the choice of healthcare professionals for over 40 years. Anprolene is used in over 5,000 facilities worldwide. [*] Unique Load Size Flexibility - The Anprolene system uses unique plastic sterilization liner bags and individual gas ampoules. We offer two different sizes of bag/ampoule combinations to match the size of your sterilization load. You never use more gas than you have to! [/list]
Chamber Width | 14 in |
Height | 21.5 in |
Chamber Height | 14 in |
Length | 22 in |
Orientation | Benchtop |
Weight | 74 lbs |
Chamber Depth | 20 in |
Width | 18 in |
