ZEISS - NC-4
by ZEISS
The OPMI Neuro/NC4 System impressively continues our tradition of techno- logical leadership in the field of microsurgery.
Every facet of the NC 4's predecessor systems was studied relentlessly by Carl Zeiss engineers and product developers. After improving upon essential components such as optics and ease of movement, ingenious "firsts" such as the integrated Heads-Up display and AutoFocus were added to ensure optimum support for new techniques such as image guided microsurgery. The neurosurgical community has validated Carl Zeiss' efforts by making the OPMI Neuro / NC 4 the most successful neurosurgical system in Zeiss' history, and by quickly establishing it as the system of choice for integration with every major image guided system.
FORUMSView All (3)
-Bug Hunter
Wed Jul 29 2020
E1 Error
Has anyone had Error E1 ... what was the cause? How was it fixed? Cheers.Reply
-Judahb_CBET_CMLSO
Wed Feb 11 2015
Multivision Head's up display strobing green when brake release button is depressed
Looking to see if anyone has had an issue when you release the brakes to move head around for positioning and the MultiVision cross hairs are activated through the head's up display ( the whole display flashes green like a strobe light. the cross hairs are still present just being wahsed out by the strobing of the head's up display).  A simple restart of the system seems to cure the problem TEMPORARILY.  I can email the short video clip if need be.
Thanks
-Turbo
Mon Jul 08 2013
I need a control button parts of zeiss nc4 microscope
I need a control button parts of zeiss nc4 microscope , Could you provide it?
  • Precision optics and ergonomics – together ensuring ease of use
  • An optical system that delivers incredible, breathtaking images and brilliant illumination is only a portion of what constitutes an outstanding microscope system. In order to be absorbed naturally into the surgical arena, the microscope needs a "silent partner" committed to comple- menting the surgeon's every move as transparently, ergonomically and efficiently as possible.
  • The power is in users' hands
  • The OPMI Neuro/NC 4 System's controls were designed with the user in mind. The handgrips, for example, provide access to every key microscope function thus ensuring an assistant is not required while the surgeon is autofocusing, taking photo- graphs or using other documentation features.
  • A microscope to match versatility
  • The OPMI Neuro was designed to accommodate virtually any neurosurgical setup and has undergone rigorous testing to be certain.
Weight285 kg
FocusingMotorized
Magnification1:6
[u]OPMI Neuro[/u]    Magnification System:    Adjustable via handgrips or foot control panel.     Focus System:     Internal, motorized, continuously variable.     Adjustable via handgrips or foot control panel.     Automatic adjustment of the working distance with laser range-finder AutoFocus. Working Range:     200-420 mm     Main Binocular Tube:     Inclinable 0-180° with 10X/21B eyepieces.            [u]NC 4 Floor Stand[/u]    Line Voltage:    115/230 V ±10%    Line Frequency:    50-60 Hz    Power Consumption:    1000 VA    Line Protection:    Automatic Circuit Breaker
