Moller-Wedel - ALLEGRA 590
by Moller-Wedel
MÖLLER ALLEGRA 590 was especially designed and optimized for dual use between ophthalmic and ENT surgeons in day clinics, surgical centers, and hospitals.
  • For coobservation, the high-resolution monitor M.DIS can be mounted to the microscope arm. A 1 CCD camera module is always integrated in the microscopes body.
  • By means of a sterilizable knob, the following diaphragm and filters can be selected: Overall illumination of the visual field, Mini spot and spot, Daylight filter, Blue filter, Green filter, Softlight filter, and Yellow UV filter
  • Red reflex enhancer
  • Motorized X-Y coupling
  • Permanently balanced
  • High movability
  • Electromagnetic brakes
  • Integrated camera
  • Inclinable eyepiece head 160° with wide angle oculars 10x 21B
FocusingMotorized
Optics: Apochromatic  Working distance: 200 mm, optional 175 mm, 250 mm, 400 mm  Eyepiece head: 160° inclinable (standard), wide-angle oculars 10x 21B  Diopter settings: +5 D to -8 D  Stereo base: 25 mm  Filter disk: 2 diaphragms, 5 color filters  Rotation: 336°  Inclination: -30° to +120°  Tilt: +/-45°
