Moller-Wedel - ALLEGRA 500
MÖLLER ALLEGRA 500 is the optimized operating microscope for all procedures that need perfect ergonomotion and optics but do not require the use of active assistance.
1Reply3 years ago | Need a fiber optic cable for this machine Moller-Wedel - ALLEGRA 500 Need a fiber optic cable for this machine , To whom i can contact in Riyadh ? Reply |
- For coobservation, the high-resolution monitor M.DIS can be mounted to the microscope arm. A 1 CCD camera module is always integrated in the microscopes body.
- By means of a sterilizable knob, the following diaphragm and filters can be selected: Overall illumination of the visual field, Mini spot and spot, Daylight filter, Blue filter, Green filter, Softlight filter, and Yellow UV filter
- 25 mm stereo base for enhanced 3D vision
- Permanently balanced
- Motorized focus, range from 200 mm to 450 mm
- Electromagnetic brakes
- Integrated 1CCD camera module
Focusing | Motorized |
Optics Apochromatic Working distance 200 mm to 450 mm Eyepiece head 160° inclinable (standard), wide-angle oculars 10x 21B Diopter settings +5 D to -8 D Stereo base 25 mm Filter disk 2 diaphragms, 5 color filters Rotation 336° Inclination -30° to +120° Tilt +/-45°
