ZEISS - OPMI 11
by ZEISS
The Opmi 11 is a great microscope for ENT surgery in the OR.
The Opmi 11 is capable of accommodating simple tubes as well as more advanced procedures. The Opmi 11 provides 5-step magnification, fine focus, a larger diameter objective lens and widerfield eyepieces. This configuration offers a single, fiberoptic lightsource with a mercury switch for on/off.
-RADNA
Wed Oct 31 2012
Dr. Richard J. Radna
Price and availability of
302615-8030; Opmi-11 gear base plate;
also need part number and availaility of the
the Opmi-11 light collector; or any variations of light collector which will fit on the Opmi-11.
Thanx,
RJR
radnarichard@earthlink.net
  • Smooth Fine-Focus Adjustment Fiberoptic Illumnation with Mercury Switch Durable Metal Components Compatible with all various mounts
Focus range54mm
FocusingManual
Binocular: Straight or Inclined; Inclinable Upgrade Available  Objective Lens: Your Choice: 150mm-400mm  Eyepieces: 10X Widefield; 12.5X Available  Pupillary Distance: 50mm - 75mm  Filter: Standard UV; Green Filter Available  Lightsource: 12V 100W  Illuminated Field: Up to 65mm  Power Source:110-240V ; 50 - 60Hz
