B. Braun - Vista Basic
Infusion Pump
The Vista® basic was designed to ensure simplicity in all aspects of its use: from set installation, to programming, to special mode use and alarm correction.
FORUMSView All (29)
2Replies2 years ago | Display not complete I have a customer that sent me one of these units and the wording above the green buttons is not there. I have the arrows once the unit is powered on but no words above the arrows. Any idea how to make them reappear? I can push the buttons and they work just can't see what we are doing.Reply |
1Reply2 years ago | manual do you have a user manualReply |
11Replies2 years ago | Constant Downstream Occlusion Hello everyone and thanks for your time and advice! B. Braun Vista Basic with constant downstream occlusion...Device primes, no problem. Each time I select the Prime option, it primes a full 25mL. Replaced occlusion sensor. Completed pressure sensor calibrations. Device still goes in to downstream occlusion alarm. Could it be AIL sensor? Since the device primes and all, I figured it couldn't be the Main PCB or Pump Head Mechanism.Reply |
- Solid, robust design of mechanical components ensures maximum durability
- Approved by and marked with UL, CSA/NRTL and CE
- Power transformer is housed in the pump, allowing a standard hospital grade power cord to be used
- Multiple warranty options are available to meet your future service needs
- Two year preventive maintenance program helps save considerable time and money from typical annual inspection requirements
- Battery life of approximately 3 years before replacement is required
Volume to be Infused | 0.1 to 9999 ml |
Height | 9.4 in |
Length | 7.8 in |
Flow Rate Range | 0.1 to 800 ml/h |
KVO Rate | 1 ml/h or selected rate whichever is lower |
Weight | 6.8 lbs |
Flow Accuracy | 5 % |
Infusion Pump Type | General-Purpose |
Width | 5.5 in |
