Ziehm Imaging - Solo
by Ziehm Imaging
Model C-Arm
Ziehm Solo is the first choice for small operating rooms. The single unit comprises a compact and versatile C-arm, full-size monitor and intuitive touchscreen user interface. All functions required for an optimal image acquisition, processing and archiving are integrated in the C-arm. Ziehm Solo delivers optimal performance for pain management, orthopedics and lithotripsy. Versatile viewing options such as the separate Ziehm Viewing Station enable the physician to configure the unit according to individual requirements. A variety of options let Ziehm Solo be configured to the needs of the application it will be used for.
FORUMSView All (8)
-Marina1975_12
Wed Feb 18 2026
Good afternoon. Please tell me, on the second large monitor after replacing the image block. became an inverted image 90 degrees counterclockwise.
-Eng Hassan
Thu May 30 2024
E 1066 can fault line active. ziehm solo
I have this error ,when the KV reaches more than 64 ,then this error appear.
Any help please
-Kronn
Mon Dec 04 2023
Password
Friends, I urgently need the passwords
  • Compact design with 24” splitscreen, flatscreen monitor or 2 x 18” flatscreen monitors mounted on C-arm
  • Footprint of only 0,8m²
  •  ntuitive user interface for easy handling on one single touchscreen
  • Clear View
  • Pulse technology up to 25 frames per second with the most compact monoblock generator for best patient access and optimal image quality.
  • 1k x 1k HD CCD camera system industry-leading, high dynamic CCD camera clearly visualizes even the tiniest anatomical structures.
  • 24" high brightness TFT monitor or twin 18TFT monochrome monitors provide optimal image display.
  • Versatile Viewing Options
  • As a standard, Ziehm Solo comes with with a rotating 24" flatscreen monitor with split function, directly mounted on the C-arm.
