GE HealthCare - Series 2000 Treadmill
by GE HealthCare
Treadmill
Advances incorporated into the Series 2000 treadmill place it at the forefront of patient safety, dependability and overall performance – the culmination of continual technological development and attention to detail specially designed to meet the high quality standards you expect from GE. The Series 2000’s extra-long, 60-inch treadmill surface provides an extra margin of safety for patients. Its zero start feature slowly builds up speed for safe and smooth operation. And it can be slowed to a gradual stop or stopped immediately with   the standard emergency stop button. Full front and side handrails are also standard on the Series 2000 treadmill.   With fewer moving parts than other treadmills, the Series 2000 treadmill delivers extremely smooth, quiet operation that facilitates accurate blood pressure measurements even at high workloads. Thanks to digital microprocessor control, its settings never need to be calibrated. And a 450-pound weight capacity and speed range of 0-13.5 miles per hour set the Series 2000 apart from other treadmills.
FORUMSView All (23)
-rajdip
Tue Mar 17 2020
calibration
for calibration we found service port and need to short pin but in our model we found rs 232 connector and not having calibration port so will pls describe which pin need to short in rs 232 connectorReply
3
-Jose 96
Fri Jan 17 2020
Error [19565] Unable to intialize acquisition module driver
Hello, I have this error code. Looking forward to your responses. Thank youReply
2
-Jose 96
Tue Aug 20 2019
GE Series 2000 Treadmill
Hello, I have a problem with the device, it doesn't function, I don't know if is the cable between the CPU and the device. Looking forward to your response. Thank you. martin_bme@hotmail.comReply
  • 60-inch walking surface
  • Two stopping modes
  • Standard full handrail set
  • Standard emergency stop switch
  • Starts from 0 mph
  • 0 to 13.5 mph speed range
  • Weight capacity of 450 lbs.
  • 0 to 25 percent grade range
Weight400 lbs
