Nellcor - OxiMax N600x
by Nellcor
The flagship monitor in the revolutionary Nellcor OxiMax pulse oximetry system.
Pulse Oximeter
FORUMSView All (10)
-AMBA BIOMED
Thu May 19 2022
error code 533 & 560
Error code 533&550 Reply
3
-Kpchu28
Wed Mar 02 2022
Cooling Fan
Hi My unit's cooling fan does not turn off even after turning off the unit after a few hours . Is this normal? Thanks in advance! Thanks!Reply
3
-LELA
Mon Jul 19 2021
BLANK SCREEN
My Nellcor N-600 has a blank screen . Do you know what is wrong with it?Reply
SERVICE COMPANIESView All Pulse Oximeter Companies
VIDEOS
PACFAQ: Common SpO2 Cables & How To Tell The Difference
  • Three display options: plethysmographic waveform, large numerics and customizable real-time trend.
  • On-screen quick guide provides instant help to assist caregivers with monitor operation.
  • Convenient selection of adult or neonate alarm limits, and user-configurable power-on settings.
  • User-selectable fast-averaging mode (2-3 seconds) to more precisely track rapidly changing saturations.
  • On-screen viewing of 24-48 hours of SpO2 and pulse rate trends taken at 2-4 second intervals; printing capability.
  • Variable pitch beep tone enables clinicians to hear changes in SpO2.
  • Backup speaker with escalating alarm tones.
  • Interfaces with certain multiparameter monitors; real-time patient information and true physiologic waveforms are displayed on host system.
  • Works with the Oxinet III remote respiratory monitoring system to provide an easy-to-use, cost-effective monitoring solution for the general care floor.
  • 7-hour battery life with battery gauge for convenient portability.
Height3.3 in
Length 6.8 in
Pulse Rate Range20-250 BPM
Weight5.7 lbs
Operating Life7 hr
SpO2 Range1-100%
Width10.4 in
  • Measurement range - SpO2: 1% to 100%; pulse rate: 20 to 250 beats per minute (bpm); perfusion range: 0.03% to 20
  • Accuracy - Saturation (% SpO2 ± 1 SD); 70% to 100% ± 2 digits; 60% to 80% ± 3 digits; low perfusion: 70% to 100% ± 2 digits; pulse rate: 20 to 250 bpm ± 3 digits; low perfusion: 20 to 250 bpm ± 3 digits
  • Electrical instrument - power requirements: 100 to 120 VAC, 200 to 240 VAC, 50/60 Hz, 20 VA; fuse rating: 0.5 Amperes
