HP - 21381A
by HP
The Philips 21381A TEE probe is utilized for pediatric transesophageal applications. It has a frequency range that operates between to 4-7 MHz and has been tested in a live ultrasound system. The HP 21381A (T6207) Ultrasound Probe is a Mini-Multi TEE Ultrasound Transducer. Ultrasound System Compatibility: Sonos 5500
[list] Philips 21381A TEE Probe functionality [*] Operating Frequency 4-7MHz [*] 3D cardiac acquisition- Adult and Pediatric [*] CW Doppler [*] Color Doppler [*] 2D imaging Philips 21381A TEE Probe Common Errors [*] CW noise [*] Color noise and artifacts [*] Articulation failure [*] Fails leakage test [*] Fluid intrusion [*] Motor control failure [/list]
| Frequency Range | 4 to 7 MHz |
