Skytron - Elite 3500
by Skytron
Surgical table
Skytron's 3500 features an incredible 21" top slide, 500 lb lift/articulation, return-to-level and return-to-center. An ultra modern table, able to satisfy all of your C-Arm and general surgery needs.
FORUMSView All (4)
4 months ago
SKYTRON 3500
I am looking for the controller for a Skytron 3500. Do you sell them
-innovativesfm
5 years ago
model # on ID plate says "3500B"
What is the difference between this and a model that does not have "B" Reply
3
-JPirillo
10 years ago
BMET
The OR has reported several times in the past week that on 4 different tables the brakes have disengaged causing the table to move? They clain the manual valve was in the right position each time. Without being present there is no way for me to verify manual valve is being set correctly, I've checked each table anf it seems to operate correctly.
[list]      [*] 500 pounds weight capacity      [*] Provides full body imaging      [*] Instant response table movements      [*] Easy-to-use pendant control      [*] Uses: urology, neurosurgery, orthopedic, cysto, vascular, E.N.T., and open heart      [/list]
Tredelenburg 25 degrees
Lateral Tilt20 degrees
