Masimo - Rad-8
by Masimo
Pulse Oximeter
The Rad-8 uses Masimo SET pulse oximetry to provide accurate readings even during patient movement or in low-perfusion situations, and to reduce false alarms by up to 95%. This unit features a large, easy to read color display and a simple to use interface for quick setup and alarm management. The compact and lightweight design is perfect for acute and alternative care settings such as long-term care facilities, homecare, and sleep labs. |
0RepliesMon Jul 17 2023 | ERROR 3 CODE After turning on the device, error 3 is displayed. This does not always happen. What is this mistake? Reply |
3RepliesThu Sep 08 2022 | Error 1 code After a couple seconds of starting device it displays error 1 and then the alarms start sounding off. It seems to go off then restart and I noticed it isn't holding a charge the entire time I was charging it? Equipment: Masimo - Rad-8 Reply |
2RepliesFri Aug 27 2021 | Rad-8 Serial Communication My friend has a daughter with HLHS. We are both software engineers. I am trying to help him retrieve data from his Rad-8 so he can monitor it from other rooms in his house, and see its history over time in a graph. Is there an api definition for the RS-232 serial communication with the device?Reply |
| Pulse Rate Range | 25-240 BPM |
| Weight | 2.1 lbs |
| Memory | 72 hr |
| Operating Life | 7 hr |
| SpO2 Range | 0-100% |
