Thermo Scientific - Shandon CytoSpin 3
by Thermo Scientific
Cytocentrifuge
The Shandon CytoSpin 3 Cytocentrifuge was the first device to use low-speed centrifugal force to separate and deposit a monolayer of cells on slides while maintaining cellular integrity.
Cytofunnels load in a tilted position to prevent cell loss. They move to an upright position during operation to deposit cells.
The sealed head protects the user from the danger of aerosoling pathogenic samples. (Load/unload within the safety of a microbiological cabinet.) Cytoclips load and unload easily without contact with the sample.
The Shandon Cytospin 3 centrifuge is useful in application areas such as hematology, oncology, cytology, histology, rheumatology, virology, serology, microbiology, and immunochemistry. The legacy Shandon Cytospin is considered to be the first reliable way to employ centrifugal force to isolate and set down a monolayer of cells on slides, at the same time preserving the cellular integrity.
FORUMSView All (14)
-cytospin 3
3 months ago
centrifuge
Running slow
Equipment: Thermo Scientific - Shandon CytoSpin 3
-cytospin 3
3 months ago
slow not running at desired speed
-gbmedts
7 years ago
cytospin 3
cytospin 3 balance
  • Multi-position cytofunnels
  • Sealed head protects user from aerosoling
  • Disposable sample chambers available in a range of sizes
  • Simultaneously spin up to 24 samples in 12 chambers
  • 9-Program memory and programmable acceleration speeds
OrientationBenchtop
Maximum Speed2000 rpm
    Capacity: up to 24 samples in 12 chambers also uses micro-titer strips
    Disposable chamber sizes: 0.1ml - 6ml
    Programs: 9 programmable memory banks
    Power: 110-120 Vac, 60Hz
