Getinge - Shampaine 1500
Electric Surgical Table with Radi-Op TopThe Shampaine 1500 consists of four sections: head, back, seat, and led. All sections are X-ray translucent material, which meets radiation standards 21 CFR subchapter J. All sections have a built-in X-ray cassette channel which will accept x-ray film packs of 14” x 17” or smaller. The table has a sliding movement to the head or foot end to allow positioning of the c-arm for fluoroscopy during surgical procedures.
The table controls are located on a single movement control arm at the head end of the table. This control arm rotates 180° laterally and has 30° of vertical movement permitting access to the controls by circulating nurse or an anesthesiologist.
The outer lifting column and base are stainless steel covered to prevent corrosion and to provide easy clean up. Hydraulics are sealed to prevent contamination. The headrest can be installed on either the back section or, if necessary to reverse the patient, the leg section.
The back section is moveable from 30° below horizontal to 90° above. . The leg section lowers 95° and raises 90°. The table is compatible with a portable or ceiling mounted image intensifier, and has standard side rails for use with all accessories regardless of manufacturer. The table is capable of six positions consisting of gallbladder, lithomy, neurosurgery (chair), proctology (jackknife), EENT and kidney. These positions are all obtainable at any height from 28” to 44”. Additional specifications include: lenght75”, width: 20” (excluding side rails), 17° lateral tilt, 25° trendelenburg and 25° reverse trendelenburg.
Powered operation of the table is by means of electricity or compressed gas, either air or nitrogen. Gas requirements are: 55 pounds per square inch minimum pressure, 125 pounds per inch maximum pressure, and 12 standard cubic feet per minute minimum flow. Air or nitrogen to be supplied by hospital.
- Electric Surgical Table with Radi-Op Top
- Four sections operating table
- All sections are of X-ray translucent materials
- The outer lifting column and base are stainless steel covered to prevent corrosion and to provide easy clean up.
Height | 28 in to 44 in. |
Length | 75 in |
Tredelenburg | 25 degrees |
Lateral Tilt | 17 degrees |
Width | 20 in |
