Curlin Medical - 2000 Plus
by Curlin Medical
Curlin Medical 2000 Plus Ambulatory Infusion Pump
The 2000 Plus is an  innovative new ambulatory pump that uses straight line PVC sets for low cost medication delivery. Straight line sets eliminate the costs associated      with using expensive pumping chambers and cassettes. Menu-driven protocols, HELP screens and easy operation provide shorter inservices and patient training times. " Curvilinear Peristaltic Action" provides a pumping technology that creates      safer, more uniform and accurate delivery of medications. Additional benefits include a choice of five therapy modes and three power sources to expand your options.            Designed and manufactured for the alternate-site markets, the 2000 Plus is a multi-therapy ambulatory electronic infusion pump capable of delivering Continuous, PCA (IV, Epidural and Subcutaneous), TPN, Intermittent and Variable modes. The 2000 Plus utilizes low-cost, all PVC administration sets; and has ability, at low rates, to deliver a resolution of flow that is up to 25 times better than the leading ambulatory pumps. These features make the 2000 Plus capable of offering significantly improved patient outcome, at substantially reduced cost to the users.    The Curlin Medical 2000 Plus provides consistent and reliable IV infusions over a wide flow range (0.1 ml to 400 ml per hour) without the need for costly pumping chambers and complex cassettes. The simplicity of its operation, highlighted by      menu-driven programs with context sensitive HELP screens, make the Curlin Medical 2000 Plus extremely simple to use.           Curlin Medical pumps give you a choice of different non-DEHP set configurations, including needleless injection sites, 0.22 and 1.2 micron filtered sets, yellow-striped epidural sets, sets with 150 ml integral fluid containers, and syringe delivery sets. All Curlin Medical sets incorporate an active, integral-flow-stop.
-Shawn1
9 years ago
Displays "No Set Installed"
Hi. I have a Curlin Medical 2000 Plus Iv Pump. I am using a brand new in date Administration set, I set up the pump according to the online PDF user manual, and I am turning the Air In Line Sensor off, as I just want to start the pump using no liquids in the line. Once I complete the menu, and it prompts me to the run/options screen, I press the run key, and it displays "No Set Installed". I am using a in date good to 2020-03-04 Ref 340-4128 Administration set. I have tried 3 sets, and still get "No Set Installed" Alarm. What could the issue be? When I power on the pump, it passes the self check. It however does have a maintenance reminder alert, but the owners manual says you can still use the pump. I contacted Curlin, and they said they no longer support this pump. Am I doing something wrong, am I using the correct admin set? Appreciate any help. Thanks. Shawn.
Infusion Pump TypeAmbulatory
