Skytron - 6600
Surgery table with removable back and leg sections.
This general purpose surgery table provides unparalleled imaging access for today’s most demanding cases while lifting 1000 pounds and articulating 600 pounds. The removable Back and Leg sections facilitate the use of a carbon fiber Back and Leg sections to further extend the imaging window. The rotating top of 210° further enhances C-arm and microscope access along with more leg room for a seated surgeon and in many cases, better surgical access. A stable footprint and rigid surface provides assurance that the patient position will be maintained as desired.
FORUMSView All (4)
0Replies2 years ago | Back section is twisting Looking at the service manual does not give a lot of info. on this issue. One side of the back section reaches the end point faster than the other. Im sure its an adjustment of a cam but which one? Equipment: Skytron 6600 Reply |
0Replies3 years ago | skytron 6600 foot switch hello, I am looking for the footswitch for this table. If anyone knows where I can purchase, i would greatly appreciate it. kimberly@medicalrv.com thank you in advance! Reply |
1Reply4 years ago | Table Top movement We have a Skytron 6600 table that was sent to us because to table top has too much movement side to side when the table is locked and the top is locked also. My question is how much movement should the table top have and what is the procedure for tightening the table topReply |
- Table can be upgraded to add an X-ray top
- Total confidence when positioning patients weighing upwards of 600lbs
- Manual brake release that is independent of main controls which requires no power to operate
- Complete set of back up controls
- 4-point "auto-leveling" braking system with brakes being located at the outer corners of the base
Tredelenburg | 30 degrees |
Lateral Tilt | 30 degrees |
Patient Weight Capacity | 600 lbs |
