TRUMPF - SATURN Select
by TRUMPF
Surgical Table
The potential applications across all disciplines and extreme ease of use make SATURN Select a reliable team player that efficiently and conveniently supports OR staff in their daily activities.
FORUMSView All (4)
-BMET_AG
Mon Dec 21 2020
Led indicators - Service required & batteries lit
Good day Comrades We have technical problems with this system Saturn Select. Fails: Led indicators - Service required & batteries lit If you have a technical manual or any idea about this situation. Reply
-suhailazzeh
Sun Aug 30 2020
noisy movement
the unit is noisy with up and down movement , oce lubricating it will be better for short time then again will become nisyReply
2
-Nomad123
Sun Jan 26 2020
independent control panel
Good afternoon, I need an additional independent control panel for the operating table. Where can I get it?Reply
  • Flexible, whatever the requirement.
  • Truly versatile, SATURN Select is ideally suited to everyday surgical work.
  • The tabletop design and longitudinal slide of 250 mm (10) provide ideal access for the C-shaped frame, and optimally support intra-operative diagnoses.
  • SATURN Select is approved for patients weighing up to 225 kg (500 lbs) (Maximum loads may vary depending on the patient´s position and OR table arrangement). A low-height version is available for laparoscopic bariatric surgery.
  • The low and standard height versions are available with the additional options: longitudinal slide and longitudinal slide with integrated body elevator.
  • Optimize and simplify work processes.
  • The robust design of the SATURN Select makes it extremely easy to use.
  • Pneumatic spring support adjustments to the backand leg sections enable the patient to be brought into the required position with minimal effort.
  • The table column uses electro-mechanical motors that provide a high level of performance, precision, safety, and hygiene.
  • Large double-swivel castors make SATURN Select extremely stable and enable it to be moved easily on soft or uneven floors.
  • SATURN Select can be operated intuitively using a remote control. The main table functions are also available from the operating panel on the column.
Height700 mm - 1120mm
Tredelenburg 30 degrees
Lateral Tilt25 degrees
Patient Weight Capacity225 kg
