Medisafe - Sonic Irrigator PCF
by Medisafe
Ultrasonic Cleaner
The Medisafe Sonic Irrigator (SI) PCF automated cleaning system is validated for cleaning and thermal disinfection of daVinci® EndoWrist® instruments. Medisafe Sonic Irrigator “PCF”- is the most versatile instrument cleaning system available today. Now available as purchase option, thermal disinfection for complex cannulated instruments both inside and out, in a fully validated and tested process. (See disinfection model option below) Cleaning then disinfecting up to 20 standard lumened instruments at temperatures up to 195ºF both inside and out, in approximately 45-minutes per cycle. Through our dedicated daVinci cycle, the SI PCF system offers an efficient and convenient way to clean up to 10 EndoWrist instruments simultaneously. For daVinci customers with EndoWrist instruments the Medisafe SI-PCF systems can perform both qualified cleaning along with disinfection by simply selecting “cycle #6” on systems digital display. For the qualified EndoWrist cleaning cycle without disinfection, select “cycle #3”. Thermal disinfection for EndoWrist instruments may not be available in all countries. Other unique feature of the SI-PCF system; automatic fill, auto pre-washing, auto enzyme injection, auto high volume sonic-flushing wash, auto high volume sonic-rinsing, auto drain. .... OR.... to add maximum versatility when needed, simply use the PCF system in a 'sonic only mode' as you would a standard ultrasonic system for walk up convenient use for cleaning basic instruments and trays.
FORUMSView All (8)
-MurrayStead
Fri May 15 2020
Calibration
Can someone please advise how to adjust the calibration for the detergent, after 4 years, yes 4 years, the dosage calibration has wandered!Reply
-KC Trading
Mon Jul 16 2018
Service and repair
I have replaced the pump on the machine and still cannot get it to work. What else should i look at.Reply
-bradleycj67
Tue Apr 05 2016
display screen does not stay on
The display screen periodically blinks off. The unit still functions during this time.
VIDEOS
  • Load instruments
  • Prewash
  • Wash
  • Rinse
  • Disinfection
  • Cooling
  • Unload
Height41 in
Length 35.5 in
Weight587.7 lbs
Width26 in
  • For indoor use at altitudes up to 2000m /6000ft
  • Operating temperature -5°C / 23°F to 91°C / 195°F
  • Humidity -80% RH max for temperatures up to 31°C / 88°F
  • Decreasing linearly to 50% RH at 40°C / 104°F
  • Designed for Pollution Degree 2, i.e. not totally sealed.
