Conmed - Aspen Excalibur
by Conmed
The Conmed Aspen Excalibur is a high power digital electrosurgical unit and features unsurpassed fulguration enhanced bipolar performance with less forcep sticking and simultaneous activiation of 2 pencils.
1ReplySat Jul 12 2025 | Como calibrar Tengo un equipo de electrocirugia conmed aspen excalibur No se como calibrar el equipo Tengo el manual de servició pero falta esa parte de Calibración Equipment: Conmed aspen excalibur electrocirugia Translation:I have a Conmed Aspen Excalibur electrosurgery equipment I don't know how to calibrate the equipment. I have the service manual but the Calibration part is missing Equipment: Conmed Aspen Excalibur electrosurgery Reply |
1ReplyWed Mar 08 2023 | Calibrating Procedimiento para calibrar el cauterio excalibur plus pc Equipment: Conmed - Aspen Excalibur plus pc Reply |
2RepliesTue Oct 12 2021 | I need the service manual The service manual I'm looking for is for the older version than the one provided. The one I need does not say "Plus PC". Mine is the predecessor to the Plus PC. Thanks!Reply |
[list] [*] Power Plus and PC Plus Models available [*] Bipolar and Monopolar [*] Multi-Purpose Electrosurgical Generator [*] Microprocessor Control provides the user with Safety and Control [*] Bipolar and Monopolar cutting and Coagulation [*] 300 Watts Output - Cut [*] Programmable Digital Display [*] Reusable Groundplate [*] Biopolar Footswitch (Optional) [*] Rolling Carts (Option) [/list]
| Height | 6.25 in |
| Length | 22.75 in |
| Weight | 40 lbs |
| OutPut Frequency | 416.7 kHz Cut. ±0.01%. Coag: 540 kHz ±10%. Bipolar: 1.05 MHz |
| Width | 15.9 in |
Pulse Repetition Frequency: Blend, spray and Bipolar Coag: 20 kHz ± 0.1%. Standard Coag: 20 kHz ±0.1% Input Voltage: 104-127 VRMS. 60 Hz calibrated at 120V Input Current: Idle: 0.8A. Pure Cut at 300: 6.5 A. Coag at 120: 2.8 A Line Frequency Leakage: Patient connected to neutral < 10 ΜA. Chassis to neutral < 25 ΜA RF Resolution: 99% Minimum Power Display Accuracy: Within 10%, or 3 watts at rated load
