CritiCare - 504DX
by CritiCare
Pulse Oximeter
Exceptionally compact, lightweight, and designed for the way you work, the 504DX series offers advanced DOX™ pulse oximetry and heart rate monitoring, plus the reliability and ease of use that have put Criticare monitors in a class by themselves. Ergonomic design and intuitive operations. Unique DOX™ digital SpO2 technology improves performance, even under the most challenging clinical conditions. Full-featured audible and visual alarms ensure accurate extended, unattended monitoring. The optional fully-integrated, internal printer produces high quality hard copies of graphic trends, tabular trends, and sleep summary reports. Sleep summary reports can be used to detect sleep apnea and requires no additional software. For additional analysis, the 504DX series is compatible with Profox* Oximetry sleep study software.
1ReplyThu Jan 31 2019 | request manual request manual for 504dxReply |
1ReplyWed Dec 12 2018 | anyone have the software for this monitor? Hi guys! Does anyone have the software for doing service on these monitors? My computer died and am looking for a copy. PN 97082A003 thanks mrstanReply |
2RepliesFri May 13 2016 | Criticare 504-US blinks once when turned on. Good night, I have a criticare 504-us that came with no power supply, after checking it, also battery was DOA. Changed battery and started to work fine, but still had to purchase original power supply #902. After that i tried again a few weeks later with the power supply but now it show sthat is connected(led indicating AC power) but when pushing power button, screen only flashes a second then shut down. And after relying only in battery power, it does not even work. I suspect it may be the ERG inverter LPS05-2-1, the TIP32 SILICON PNP SWITCHING TRANSISTOR or something else at the power supply. All capacitors seems fine, diodes and zener diodes look good, also measured them all. If you have service manual and/or advice, i'll appreciate it. Reply |
| Height | 5.67 in |
| Length | 4.81 in |
| Pulse Rate Range | 20-300 BPM |
| Weight | 3.34 lbs |
| Memory | 24 hr |
| SpO2 Range | 0-100% |
| Width | 7 in |
