ARKRAY USA - SPOTCHEM EZ SP-4430
by ARKRAY USA
SPOTCHEM EZ performs biochemical measurements easily with the dry method and solid phase reagent. A built-in compact centrifuge reduces pretreatment of samples before measurement. SPOTCHEM EZ is a most-advanced dry chemistry analyzer.
2RepliesWed Sep 10 2025 | T12 appear how to fix troble schooting T12 occur Equipment: ARKRAY USA - SPOTCHEM EZ SP-4430 Reply |
1ReplyTue Aug 31 2021 | Error T28 Buenas tardes, quisiera saber si tiene disponible el manual de servicio de este equipo, muestra en pantalla el codigo de error T28, me podran ayudar a identificar que causa la falla y como resolverlo? de antemano muchas graciasReply |
3RepliesTue Aug 24 2021 | Error T12 Firstly was E05 error. After fixing it by cleaning procedure, it changed to T12 error - optical gain. I checked windows, black and white plates, everything is OK. How can I fix this problem?Reply |
[list] [*] Compact & lightweight - Only A4 sized space for installation [*] Built-in compact centrifuge [*] Simple operation [*] Easy calibration with magnetic card [*] Multi-type reagent (with 5 or 6 items) by disease [*] Management by barcode is available. [/list]
| Height | 167 mm |
| Throughput | 63 samples/hr |
| Length | 203 mm |
| Detector | Silicon Photodiode |
| Power Requirements | 100-120 VAC |
| Weight | 5.4 kg |
| Light Source | LED+Interference Filter |
| Sample Types | Serum, Plasma, Whole blood (only Hb) |
| Width | 338 mm |
