GE HealthCare - Giraffe Incubator
by GE HealthCare
Infant incubator
Combining innovative technology with exceptional thermal performance, the Giraffe Incubator Carestation is a state-of-the-art neonatal environment that promotes natural, peaceful healing, while fostering a close bond between families and their babies—allowing them to be present for every step of the journey. Additionally, physicians have improved access to their smallest patients, giving them a better chance at providing successful treatment, the very first time around.
FORUMSView All (10)
-VegaD
Fri Mar 28 2025
"Fan Always in High Speed"
Hi MedWrench,
I have a GE Datex-Ohmeda Giraffe Incubator that came down to the workshop recently. After Power On, and temperature is set, it works fine for a while and then pops up with the message "Fan Always in High Speed".
Via Alarm review, it indicates "Heater temperature sensor has failed"
Now, my question is this - Is this referring to:
  1. The heat sink thermostat - p/n: 6600-1019-600  or
  2. The high speed sensor - p/n: 2081533-001
Kindly advise
Equipment: GE HealthCare - Giraffe Incubator
-Adil.younus
Wed Jan 24 2018
Motor Drive Failure
Got an Omni Bed with error 'motor Drive failure' - manual says to replace the whole relay board! Don't want to do that just now. Anybody got any idea where to start looking? The bed does not move AT ALL in the normal mode, however, its intermittent in service mode. Makes a bit of movement and stops even when the pedal is pressed. Any help would be appreciated! Thanks, AdilReply
-Ckeaton
Wed Sep 14 2016
Calibration of O2 Blender
I wish to overhaul, calibrate and test the O2 blender in the Giraffe seperately. I need to be able to connect the blender to source gas directly.  50 psi Air and O2.  I  ordered GE Test Kit 99857861 but it did not have the components to connect directly to source gas.  What is the part numbers needed for me to connect my blender directly to source Gas?  The O2 Air and Air inlets are different then a standard Bird O2 blender.
[list]    [*] Dovetail Rail Mounting System - Provides mounting for full line of GE Healthcare accessories         [*] Patented Baby Susan Rotating Mattress - unique rotating mattress allows the clinician to rotate the bed 360 degrees for optimal patient access         [*] Dual Access Doors and Gumdrop Shaped Portholes - Maximizing accessibility and comfort for the caregiver          [*] Large Pass Through Drawer with Sliding Organizer - Provides ample storage for blankets, diapers and family items         [*] Large 19" Mattress - Provides clinicians with space to care for larger babies or multiple bedding         [*] Integrated X-ray Cassette Tray - Minimizes patient distubances and X-ray may be taken in open or closed bed mode.    [/list]
Height33 in
Length 45 in
Weight304
Width26 in
Mattress size: 25.5 in x 19.2 in
Drawer size: 19 in x 20 in
FDA AlertsView All
GE Healthcare, LLC Recalls Giraffe Infant Warmers and Panda...
Class I Recall: GE Healthcare, Giraffe Warmer with Resuscitation...
The oxygen and air wall inlet fittings on the back panel of the resuscitation systems were reversed during assembly.
Class 1 Recall: GE Healthcare, Giraffe OmniBed and Giraffe...
The Giraffe OmniBed can function as an incubator (closed mode) or as a warmer (open mode) and can transition from one mode to the other on the user’s demand. Incubators and warmers are used to maintain the body temperature of a newborn baby.
