Siemens - ADVIA Centaur CP
by Siemens
A high-throughput benchtop system that enhances your in-house immunoassay test capability.
The ADVIA Centaur CP System is an immunoassay test instrument for mid-volume labs. Its broad menu lets users both expand and consolidate – by bringing a wide range of assays to one workstation, eliminating redundant systems. The ADVIA Centaur CP System is easy to operate, increases efficiency and streamlines workflow. It offers the excellent sensitivity and specificity expected from direct chemiluminescence technology.
FORUMSView All (9)
-Israel Reyna
Fri Mar 08 2024
Demographic Data imput option dissapear
HI, In our equipment, we were previously able to input the patient's demographic information but are now unable to do so.
The person using the equipment only changed the language and enabled the quality control option.
We attempted to switch the language back to its original setting and disable the quality control component, but the option for patient's demographic information just dissapeared.
Now we could only input the ID
 What could be some possible solutions to this issue?
-samdeck33
Sat Dec 24 2016
In search of Centaur XP Parts List
I am in need of a parts list for the XP, more specifically which parts it has that differs from the Centaur Classic. Any help will be much appreciated!
-catmomma58
Fri Oct 28 2016
Looking for information on interference of lithium heparin for tests on Centaur and Vista
Interested in knowing if lithium heparin interferes with the following tests:
FETO, C2729, CEA, CORT, PTHI, PROG
Thank you for any assistance
  • The fast throughput users need with a mid-volume immunoassay system.
  • Uninterrupted system processing when loading samples, reagents, and consumables.
  • Supports STAT samples as well as test prioritization of routine samples.
  • Advanced features such auto dilution, reflex, and reruns without operator intervention.
  • Takes ready-to-use reagents straight from the refrigerator, the same reagents as the ADVIA Centaur XP System.
Throughput180 samples/hr
Reaction Time15 min
Assays on board: 15       Total assay capability: 100
