ASP - EVOTECH
by ASP
Efficiency and Peace of Mind
The EVOTECH® Endoscope Cleaner and Reprocessor (ECR) is the first commercially available system that both cleans* and high-level disinfects endoscopes. With a safe and fast automated process, it simply makes labor-intensive and time-consuming manual endoscope processing a thing of the past.      [list]      [*] Eliminates tedious brushing, giving you more time to care for patients      [*] Consistently automates critical process steps for an added level of confidence      [*] Performs complete monitoring of critical parameters including MEC, block detection, temperature and pressure every second of the cycle      [/list]      The integrated solution of the EVOTECH® ECR, plus CIDEX® OPA•C Solution and CIDEZYME® XTRA Enzymatic Detergent Solution is specially formulated for cleaning and high-level disinfection of heat-sensitive (>60° C) endoscopes.
FORUMSView All (5)
-SRMartin
5 years ago
Parts and manual
Looking for a source for parts and a service manual, other than asp. Reply
3
-T. Thomas
6 years ago
Olympus Bronchoscope Compatibility and Setup
Error messages "channel pressure too low" and "low flow channel 1" keep appearing. Have checked connectors and tubing for integrity. Trying to reprocess an Olympus bronchoscope. How do we properly attach all tubing to the device to ensure this is being done properly?Reply
2
-nutronics
8 years ago
Service manual to this device
I need the service manualReply
Consistent Cleaning for Complete Confidence      The first of its kind, the EVOTECH® Endoscope Cleaner and Reprocessor makes endoscope reprocessing a totally automated process. Now you can improve safety, prevent infection, and save valuable time.      [list]      [*] Dual independent basins give you the ability to efficiently run separate simultaneous cycles      [*] Closed system reduces worker exposure to chemicals and delivers fresh CIDEX® OPA•C Solution and CIDEZYME® XTRA Multi Enzymatic Detergent for each scope cycle      [*] Built-in alcohol flush promotes drying and prevents bacterial growth      [*] Integrated computerized monitoring allows tracking of all critical cycle parameters      [*] Printer and optional bar code scanner help you with data management tasks      [/list]
Height46 in lid closed
Length 33 in
Weight500 lbs when empty
Width37 in without printer
TECHNICAL SPECS      System      Total Cycle Time      33 minutes or less (under nominal conditions)            Capacity      Basins Per System 2      Scopes Per Basin 1      Basin Size 18.25 in x 19.75 in x 5.75 in            Electrical Requirements      EVOTECH® ECR 208 VAC, 3~, 60 Hz, 30 A, 4-Wire      3-phase NEMA L 15-30      Printer 110 VAC            Water Requirements      Pressure 40 PSI (275 kPa) minimum dynamic pressure during flow rate of 1.6 gallons per minute per minute at EVOTECH® ECR inlet per basin      Hardness Soft water      Incoming Temperature 41°F to 86°F (5°C to 30°C); usage may be affected below 59°F (15°C)            Germicidal Agents      Agents CIDEX® OPA Concentrate Solution            Operational Environment      Temperature 64°F to 86°F (18°C to 30°C)      Relative Humidity 10% to 80% noncondensing      Elevation 3000 meters (maximum)
