Medline - Perfectemp Warming System VI Packs
by Medline
The Surgical Care Improvement Project (SCIP) is a national quality partnership of organizations focused on significantly reducing surgical complications. PerfectTemp helps you comply with SCIP Measure 10, which recommends the use of active warming intraoperatively to achieve the target temperature of 36 degrees C within 30 minutes before or 15 minutes after anesthesia end time. The measure applies to patients of all ages undergoing surgical procedures under general or neuraxial anesthesia for 60 minutes or more.
[list] [*] The only warming system available that helps monitor the temperature at the point of contact between the pad and the patients skin [*] Helps ensue the patients temperature is constantly monitored and maintained for normothermia [*] PerfecTemp OR table pad helps meet SCIP-Inf-10 by combating hypothermia and reduces the risk of pressure ulcers [*] An economically efficient alternative to the current warming systems [*] Substantially cuts set up time and equips each OR with a silent, nonrestrictive warming device [*] PerfecTemp bundles feature a control unit, patient cable, power cordand various warming mattresses to fit your OR tables [*] Count on the pads' two foam layers and thin, plastic heating element to evenly warmyour patients and actively control normothermia [*] Complies with SCIP Measure 10 [*] Advanced Technology for Uniform Patient Warming [*] Easy to use [*] Helps Avoid of pressure ulcers [*] Latex free [/list]
Medline PerfecTemp PerfecTemp is an O.R. table pad that incorporates both pressure-reducing high-tech material to reduce the incidence of pressure ulcers and a warming system to combat hypothermia. PerfecTemp is the only warming system available
