Thermo Scientific - CR4-12
by Thermo Scientific
Includes a 4-place horizontal rotor with four 750 ml buckets and four inserts. The unique combination of heating and refrigeration ensures very precise control of temperatures above ambient – especially important when it is necessary to centrifuge samples at physiological temperatures.
4RepliesWed May 13 2015 | TRANSISTOR REPLACEMENT Transistor Q5 is burnt that its code can not be seen, can you help me please. Reply |
1ReplyWed Apr 01 2015 | repair can you give me the circuit diagram of the electronics board with part number 38595. Reply |
0RepliesWed Apr 01 2015 | repare can you give me the code for the transistor in the main electronics board of the centrifuge. Reply |
| Height | 420 mm |
| Length | 600 mm |
| Weight | 220 lbs |
| Width | 820 mm |
[list] Swing-out Rotor Maximum Speed/RCF is 4,500 RPM / 4,300 x g Swing-out Rotor Maximum Capacity is 4 x 750 ml Angle Rotor Maximum Speed is 8,000 RPM Angle Rotor Maximum RCF is 9,320 x g Angle Rotor Maximum Capacity is 8 x 100 ml Timer is 30 min Timer Hold Position Brakes in 2 rates Acceleration is Fixed Temperature Range is -8° Celsius to +40° Celsius, 4° Celsius at max. speed Maximum Power is 1,300 vA. [/list]
