GIMMI - ALPHATOMENDO 400
by GIMMI
The newly developed GIMMI ALPHATOMENDO 400 electrosurgery unit, capable of developing up to 400 W power, covers all bipolar and monopolar surgicaland endoscopic applications. The ALPHATOMENDO 400 reaches its peak performance especially in open surgery (cutting and coagulating) and as a so-called “underwater cutting” in urology. Specially designed for endoscopic applications (e.g. papillotomy or polypectomy) a time-controlled cutting mode generates a fractionated and therefore monitored cut in the so called “endo-modo”.
-Ahmed7090
2 years ago
GIMMI alphatom 400
is the probes are universal type for this machine or notReply
-sabo
13 years ago
GIMMI alphatom 400
I need service manual for calibration
termcauter alpha tom 400 t.9400.00
The ALPHATOMENDO 400 is further equipped with a progressive power control for very fine adjustments in the lower power range and high power reserves in the upper power range. Its clear design for safe and simple operation, the high patient safety level thanks to the “Patient Control System” and the routine self-check during system startup are further typical GIMMI features found with the ALPHATOMENDO 400.    A foot switch is available as an option for this robust micro­processordriven unit.
