GYRUS ACMI - Dolphin II
by GYRUS ACMI
DOLPHIN II Hysteroscopic Fluid Management System
In operative hysteroscopy, the surgeon and O.R. staff work hard to protect the patient against the dangers of fluid intravasation. Manual methods are complicated, time-consuming, and imprecise. A better solution is the DOLPHIN II Fluid Management System for hysteroscopy, designed by ACMI, a market leader in endoscopic irrigation. It has been developed to provide simple, accurate, and reliable fluid management for improved patient safety and enhanced surgeon confidence.      Warns user of high pressure, or when fluid exceeds user-set deficit level            Provides Accurate, Real-Time Measurement of Fluid Deficit & Pressure During Hysteroscopy & Resection. In operative hysteroscopy & resection, the surgeon and OR staff work hard to protect the patient against the dangers of fluid intravasation. Manual methods are complicated, time-consuming, and imprecise. A better solution is the DOLPHIN® II Fluid Management System for hystero­scopy, designed by Stephen L. Corson, MD and Gyrus ACMI, a market leader in endoscopic irrigation. It provides simple, accurate, and reliable fluid management for improved patient safety and enhanced surgeon confidence.
-James
Mon May 21 2012
Dolphin II
Does anyone have a maintenance manual for the GYRUS ACMI Dolphin II - Hysteroscopic Fluid Management System. We need to see the PM requirements and procedures.
[list]    [*] Built-in warning systems      [*] Measures fluid inflow and outflow by weight comparison      [*] Displays necessary information      [*] Nonpulsatile, even-pressure pump      [*] Easy to operate      [*] Real-time accurate monitoring of fluid deficit      [*] Easy-to-read control panel displays fluid deficit, driving pressure, and user messages    [*] Steady distention of uterus and clear visualization from 40 to 140 mm Hg      [*] Prompts user through patient setup and indicates when bag needs to be changed      [/list]
