Boston Scientific - Endostat III
by Boston Scientific
The Endostat III Generator is intended for use in GI Endoscopy. This unit is designed to have both bipolar and monopolar electrosurgical capability.
0RepliesFri Jan 15 2016 | pm Reply |
0RepliesMon Jan 14 2013 | Service Manual I am trying to find a service manual for the Endostat III. I am needing the PM procedure for these units. Any help would be greatly appreciated. Thanks Reply |
4RepliesMon Jan 14 2013 | PM Procedure/Service Manual I am trying to find a service manual for the Endostat III. I am needing the PM procedure for these units. Any help would be greatly appreciated. Thanks Reply |
[list] [*] A self-limiting energy system that is designed to limit the depth of burn penetration. [*] A variable speed peristaltic pump intended to provide precisely controlled irrigation. [*] Two bipolar modes: CONTINUOUS or VARIABLE TIME, designed to vary the duration of energy delivery. [*] The monopolar capabilities of the Endostat III Generator are intended to provide physicians the ability to perform certain therapeutic procedures using standard monopolar devices such as polypectomy snares, sphincterotomes, and hot biopsy forceps. [*] A choice of four individual RF waveforms: COAG, BLEND, CONTROL CUT, or CUT. [*] Receptacles that accept widely used monopolar active cords and disposable dispersive electrodes (patient plates, or grounding pads). [*] The Endostat III Generator also features a new safety standard that utilizes two separate warning systems intended to help identify the cause of a problem and prevent surgical error. [*] The “Pad Fault” warning system is designed to detect a poor connection between the generator and the pad or between the pad and the patient. In the event of a fault, the RF power is designed to be inhibited until the connection is corrected. [*] The unit is also designed to monitor the output and the internal power supplies. If the output or internal supplies exceed their specified limits, the unit is designed to go into a “System Fault” condition, which is intended to prohibit any output. Also, the unit is designed with a maximum single power application time limit of 22 seconds, as a safety feature in case of a footswitch activation failure. [/list]
