Valleylab - SSE2L
The Valleylab SSE2LThe Valleylab SSE2L generator provides a consistent high level of performance and safety in the surgical suite, clinic, office and outpatient surgery center.
FORUMSView All (12)
1Reply3 years ago | ISOBLOC BOARD BURNED R1 WHEN TURN ON THE MACHINE Hi there. I have a sse2l and the problem is when i turn on the machine the isobloc board R1 resistor got burned. What is the cause of burned resistor in isobloc? I already isolate the isobloc board and where the output supply came but all the components seems good and no suspicious etc. Please i need help thanks in advance...Reply |
1Reply3 years ago | Réparation La manche fonctionne bien mais la coagulation et la coupure ne fonctionne pas. Tout les fusible marche. aidez moi Svp Reply |
1Reply3 years ago | Grounding Pads Good Afternoon, My office needs to know which grounding pads are compatible with the above listed device. Please advise. Thank you. PattieReply |
It accepts all standard Valleylab accessories to help meet the surgeon’s needs, in a wide range of general procedures and in specialties including gynecology, urology, thoracic, and plastic and recovery surgery.
Height | 7.6 in |
Length | 16.6 in |
Weight | 32.5 lbs |
OutPut Frequency | 500 kHz |
Width | 11.6 in |
Output Waveform: Cut: 500 kHz sinusoid with 65% 120 Hz modulation. Blend: 500 kHz sinusoidal bursts at 20 kHz. Coag: 450 kHz damped sinusoidal busts with repetition frequency of 20 kHz. Bipolar: 500 kHz sinusoid, unmodulated. Output power changes no more than ±20 watts in cut/blend mode, or ±12 watts in coag mode between 100-130 AC volts input. Low Frequency Leakage: Source current: less than 0.2 ΜA rms. Sink current: less than 100 ΜA rms. Patient leakage: less than 150 ΜA rms. Line ground leakage current (50/60 Hz) unit off – 10 ΜA rms, unit on – 30 ΜA rms High Frequency Leakage: Less than 150 mA rms, all outputs. Input Power Requirements:Operation range is 90-135 AC volts. Currents less than 12 amperes in cut, and less than 4 amperes in coag. REM™ System: Measurement frequency: 140 kHz ±20 kHz. Measurement current: 3 mA maximum. Acceptable resistance ranges: REM™ pad – 5-135 ohms, non-REM™ pad – 5 ±2 ohms
