Newport Medical - e500
e500 VentilatorWhen critical care meets innovation, you get truly intuitive care - you get the Newport e500 Ventilator. With its Intelligent Control™ System for maximum patient/ventilator synchrony, easy-to-use control panel, and a touch screen graphics display monitor; the e500 is the patient-focused ventilator of the future. Designed for simplicity of use, the e500 offers direct access to all ventilation controls along with other frequently used functions such as Inspiratory and Expiratory Hold, 3 min Oxygen, Suction Disconnect and Preset Vent Settings. The logical layout of the front panel and smart alarm systems make ventilator setup and training quick and easy. And the self-calibrating, integrated oxygen monitor with alarms, the panel lock, and an internal battery all provide the smooth ventilator management necessary to assure peace of mind. Exclusive to the e500 ventilator, the e500 Graphics Display Monitor features a clear view of diagnostic information with touch-screen ease. In addition to 24 hour trend data, the GDM provides an Event History Log that records the 600 most recent occurances of both alarm violations and changes to ventilator settings. The Wave/Loop Freeze with Cursor function allows the user to gather the analysis of time, pressure, volume or flow at any point in the breath.
FORUMSView All (4)
2Replies7 years ago | The Graphical unit does not communicate with Gas Delivery unit I have E 500 Unit where the ventilation is perfect but the Graphical unit does not communicate with Gas unit , Have tested the graphicak unit in other known good unit ,the Graphical unit is OK , The connection of the Screen on the back of Gas Delivery unit is OK , Please suggest further action .Reply |
1Reply8 years ago | Mr Taju Ogunremi Tech Manager We are having problem with Newport ventilator model e-500, the two fuses at mains soket at the back of the ventilator bloned, please we need your adiverse on wthat to do.
with best regards Taju Reply |
0Replies11 years ago | I'm confused
hello. i have a newport e500 mechanical ventilator, it has a alarm shows that I:E is inverted, the ventilator parameters are Vt 500 FV 12 fiO2 0.50 Tl 12 peep 2 and still shows the alarm, i don't know how change inspiratory volumen. I search in many web pages the manual but I don't found anything.. Please help me. Where i can found the manual? Reply |
[list] [*] Intelligent ControlSystem - FlexCycle™ Flexible Pressure Support Cycling Threshold, Automatic Slope/Rise Adjustment, Automatic Leak Compensation, Dual Control Breath Management (VTPC/VTPS) [*] Suction Disconnect - Press and hold Alarm Silence for one second to enable. Suspends ventilation while delivering continuous flow after a planned disconnect [*] User Set Up Functions - Leak Test, Circuit Compliance Compensation (calculate and enable breathing circuit compliance of flow/volume delivery), enable 90-second Slow Inflation, Altitude Compensation, Language Selection, Violation Message Log [*] Bias Flow - Ventilator-set bias flow flushes exhaled CO2 and stabilizes temperature, humidity and baseline pressure in the patient breathing circuit [*] Non-invasive Ventilation - Compatible with mask ventilation for continuous or short term use [*] O2 Calibration - Automatic oxygen sensor calibration at software determined intervals [*] Preset Vent Settings - Mode, Breath type and settings can be preset without affecting current ventilator operation [/list]
