Zyno Medical - Z-800
by Zyno Medical
Zyno's flagship product, the Z-800 Infusion pump is ideally suited for basic infusion needs in alternate care environments such as oncology, ambulatory infusion centers, specialty pharmacy/Long-term care, and home care.
1Reply3 years ago | Battery Test What specifications are needed to run a battery test for the Zyno-800F pump? How many mLs? How much VTBI? How long (hours/minutes) should the pump run at that rate(s)?Reply |
1Reply5 years ago | Need the PM reset procedure for Zyno Z-800F I get a message that preventative maintenance is due soon, but am unsure how to reset the counter. I've done the maintenance, but Zyno won't provide any help since I haven't been to the seminar. Could anybody help out? Thanks, -MattReply |
4Replies6 years ago | Zyno Z800 F Does anyone have the code so i may go in and reset the odometer for the Zyno Z 800 F ? I saw a post in the past few months and i was wondering if they received the code. Reply |
Flow Rate Range | 1 to 9999 ml/h |
Volume to be Infused | 1 to 9999 ml |
Height | 8.6 in |
Length | 5.3 in |
Weight | 5.7 lbs |
Width | 5.7 in |
