Siemens - MAGNETOM Aera
MAGNETOM Aera will fundamentally transform the way users work with MRI.
Through the groundbreaking integration of Tim 4G and Dot, MAGNETOM Aera sets a new standard of efficiency, ease of use, and care which will help users harness a new level of productivity.
FORUMSView All (6)
3Replies4 years ago | Offline Getting a "Scanner Offline" Error, and I'm the New Biomed to the hospital with zero experience with this machine and the other workers are either out of town, or out sick. Help! -- Thanks!Reply |
0Replies7 years ago | Meaning of numeric values of Hamming Raw filter What is the meaning of the numeric value that can be entered set for the Hamming filter? Is it the alpha or beta value from the signal processing definition of the Hamming filter?Reply |
SERVICE COMPANIESView All MRI Systems Companies
- Greater patient access and comfort with 70 cm
- Ultra-light and short 1.5T system - (145 cm cover to cover, 3121 kg)
- DirectRF - for higher signal purity and improved stability
- 50 x 50 x 45 cm FOV with TrueForm Design
- Tim Dockable Table option - Mobility done right
- Illumination MoodLight providing comfortable environment
NEWSView All
Siemens Healthineers Introduces GOKnee3D MR Application
Novel application reduces scan time for MR imaging of the knee in half, helping both radiology providers & patients. Enables clinically validated, high-resolution isotropic 3D knee exam with all relevant contrasts & evaluation in all imaging planes
