Bovie - Aaron 950
by Bovie
Introducing the Aaron 950, the first and only High Frequency Desiccator with Cut.
Introducing the Aaron 950, the first and only High Frequency Desiccator with Cut. You might call it a split personality. One half of the unit is a high frequency desiccator, out of the mold of our very popular Aaron 900. The other half is a Bovie® Generator, giving you 60 watts of cutting power and coag capabilities – plenty of power for LLETZ/LEEP or most any cutting procedure performed in the doctor’s office.
3-Button Pencil
The three button pencil is a masterpiece of engineering. It allows you to adjust the power output up and down as well as to activate the unit, even when you are in foot control mode!
Designed For Years of Trouble-Free Use
The Aaron 950 is designed and engineered to be the most reliable and durable generator available today. The unit’s life is prolonged by incorporating the latest in chip technology and reducing the number of internal parts, thereby generating less internal heat. Unit cleanup is simplified by its non-absorbing, nonstaining, high-impact ABS enclosure.
Compact, Mobile, Electrosurgical System
Standard package includes the unit, power cord, reusable handpiece, 10 handpiece drapes, five disposable active electrodes, 50 sharp dermal tips, 50 blunt dermal tips, one reusable dispersive cord, five disposable dispersive electrodes, user’s guide, and wall-mount kit.
-pmrpepair
2 years ago
Service Manual
Is there a service manual available for the 950 unit. I am needing a part number or part availability for the pencil trigger switch receptacle on the bottom of this unit. Reply
  • 60 Watts – Cut, Blend, Coagulation
  • Isolated Power
  • 6 Presets – For The Doctor’s Favorite Settings
Height7 in
Length 4.5 in
Weight8 lbs
OutPut Frequency350 kHz -800
Output Power60
Width10.25 in
