HESKA - DRI-CHEM 4000
by HESKA
Designed to deliver accurate results while maximizing testing flexibility.
Choose from individual tests and pre-packaged panels. Easy to use features like automated dilution, stackable slide racks and multiple sampling options make the DRI-CHEM 4000 an important part of any in-clinic lab.
-Jayme MDP McKelvey
Tue Aug 21 2012
DRI-CHEM 4000 Chemistry Analyzer
Video on DRI-CHEM 4000 Chemistry Analyzer
VIDEOS
[list]        [*] Electrolytes and More: Electrolytes on one slide, individual slide options, and pre-packaged panels including the Comprehensive Plus, let you configure the profiles you require.        [*] Completely Automated Dilution: No guesswork on measuring dilutions or calculating results. The DRI-CHEM® chemistry analyzers provide automated dilution and results calculations on every parameter for samples outside of measurable limits..        [*] Sampling Flexibility: Choose the 1.5-ml heparinized sample tube or pipette serum or plasma from your regular red-top or green-top tubes into a non-heparinized tube.        [*] 3 Steps to Getting StartedStack and Run: Load up to 22 tests (20 slides) at one time without jamming, using the convenient stackable slide rack.        [*] Whole Blood Solution: Heska’s lithium heparin sample tubes save you a step. Go from syringe to centrifuge to analyzer with no pipetting required.        [/list]
Height16.5 in
Sample Capacity20 slides simultaneously per cartridge
Throughput128 samples/hr
Length 14.2 in
Power Requirements100-240 VAC
Weight53 lbs
Light SourceHalogen lamp (6V, 10W)
Width18.5 in
[list]  Incubation Temperature: 98.6° F (37° C) (CM); 86° F (30° C) (ISE)  Number of Incubator Cells: CM 12, ISE 1   Measurement Accuracy: ± 0.005 OD (600 nm)        Display: 5.7 in. color touch panel  [/list]
