Stryker - Visum LED II
by Stryker
Building upon years of surgical lighting experience, Stryker has raised the bar again with the Visum LED II Surgical Light. Using best-in-class LEDs (Light Emitting Diodes) and a proprietary reflector design, the Visum LED II provides world-class lighting for your OR. With maximum brightness and exceptional shadow resolution as the keys to success in surgical lighting, the Visum LED II provides a large column of light and exceptional shadow resolution. This is achieved while providing pure white light that will remain cool under the most demanding conditions. The Visum LED II requires very little maintenance and no bulb changes during ownership due to long lasting LEDs.
1ReplyTue Sep 03 2024 | PESO DE LA LÁMPARA? Hola, alguien sabe el peso de la lámpara? Hello, does anyone know the weight of the lamp?Reply |
1ReplyWed Aug 22 2012 | power supply Stryker Visum- looking for schematics for Stryker visum power supply Reply |
41” Column of Light Large spot size and depth of field provides a large column of light, decreasing the need to adjust the light during a procedure Superior Shadow Resolution Stryker’s proprietary reflector technology effectively resolves shadows to keep the surgical site clearly illuminated while maintaining a large depth of field Single Color LEDs Provides 160,000 lux of pure white light Low Heat Output LEDs do not emit UV or Infrared light waves, helping to keep the OR staff cool even during long cases, and creating a more comfortable work environment No Bulb Changes LEDs eliminate the risk of bulb burn out during a procedure, decreasing operating costs and downtime while increasing your return on investment Compact, Light-Weight Suspension Allows for easy repositioning during surgical procedures
| Bulb Life | 20000 hr |
| Color Temperature | 4400 K |
