MRIequip - MRI Non-Magnetic Fixed Bariatric Stretcher
by MRIequip
MRI Non-Magnetic Fixed Bariatric Stretcher 600lb. Capacity
This non-magnetic fixed MRI Bariatric Stretcher boasts a generous 600 lb weight capacity and convenient 22" x 31" storage tray below. Comes standard with four locking casters, grounding chain, stretcher pad is covered with Medical Grade Sure-Check Fusion III material. Fowler back head rest adjusts from 0 to 75 degrees. Non-marring bumper protects on all sides. Flip down side rails provide easy accessibility.    This non-magnetic MRI bariatric gurney is constructed entirely of non-ferrous materials. Specifically designed for use in and around the MRI suite. All materials including fasteners and bearings are either non-ferrous metals or special polymers.
-MedWrenchManager
12 years ago
MRI Safety Stretcher
This is the MRI Non-Magnetic Fixed Bariatric Stretcher with a 600 lb. Weight Capacity. It has a convenient 22" x 31" storage tray below. Comes standard with four locking casters, grounding chain, stretcher pad is covered with Medical Grade Sure-Check Fusion III material. Fowler back head rest adjusts from 0 to 75 degrees. Non-marring bumper protects on all sides. Flip down side rails provide easy accessibility.
VIDEOS
[list]      [*] Stainless Steel construction      [*] Drop down side rails      [*] Grounding chain      [*] Storage tray       [*] Full surround rubber bumper      [*] Adjustable headrest    [/list]
Height30.3 in
Length 77 in
Weight130 lbs
Patient Weight Capacity600 lbs
Width29.3 in
Casters: 4x 5" Swivel locking
