Fluke Biomedical - ESA615
by Fluke Biomedical
Test to any standard in minutes
The ESA615 Electrical Safety Analyzer is a fully integrated, portable solution tailored for biomedical engineers and healthcare technology management (HTM) professionals performing electrical safety testing on medical equipment in both field and facility settings. Combining the functions of a multimeter, electrical safety analyzer, and ECG simulator, the ESA615 delivers fast, automated testing that meets global compliance standards.
Engineered for comprehensive testing, the ESA615 performs all key safety checks, including:
  • Line (mains) voltage
  • Ground (protective earth) resistance
  • Insulation resistance
  • Device and patient lead (leakage) current
  • Point-to-point voltage, resistance, and leakage tests
  • ECG simulation
The ESA615 supports all major international electrical safety standards: ANSI/AAMI ES-1, NFPA-99, IEC 60601-1 (2nd & 3rd Ed.), IEC 62353, VDE 751, and AS/NZS 3551, making it ideal for global medical device compliance testing. (Generated by AI)
FORUMSView All (3)
-MedWrench Intern
Sun Jun 24 2018
ESA 615 Electrical Safety Analyzer
The automated ESA615 Electrical Safety Analyzer performs all primary electrical safety tests per the latest electrical safety standards. It also performs ECG simulation and point-to-point voltage, leakage and resistance tests.Reply
-fanies
Wed Apr 26 2017
Fluke ESA615 with no AC output
Hello, I have a Fluke ESA615 which does not apply voltage to DUT through L1 and L2. All fuses checked OK. What could be causing this issue?Reply
-LOCATI
Mon Mar 21 2016
Calibration date
How can I change the calibration date in the memory of the unit?
Thank you
VIDEOS
  • Portable: Lightweight with a built-in handle and protective carrying case, perfect for mobile service teams.
  • Simple: Intuitive push-button interface, large display, and automated test sequencing for ease of use.
  • Connected: Supports plug-and-play data entry via keyboard or barcode scanner, plus easy data transfer via wireless or SD card. (Generated by AI)
Height28.5 cm
Length 8.4 cm
Weight1.6 kg
Analyzer/Simulator TypeElectrical Safety
Width17.6 cm
NEWSView All
Fluke Announces Advantage Training News for April
Fluke Biomedical Advantage Training News
No-cost training on medical device performance and safety testing, documenting for regulatory compliance, productivity improvement, and using test instruments effectively.
