Abbott - Aeroset
by Abbott
The instrument uses a dual-pipetting system with a maximum throughput of up to 2000 tests/hour. It can be configured with up to 100 different assay files utilizing photometric and potentiometric methodologies. The potentiometric assays (Na+, K+, and Cl-) are measured using an Integrated Chip Technology™ (ICT™). The Abbott Aeroset System will process routine and STAT samples using independent Carousel and FastTrack™ Samplers.
Height | 43.5 in |
Length | 44.1 in |
Weight | 1500 lbs |
Width | 74.5 in |
