Abbott - Architect C 16000
by Abbott
The ARCHITECT c16000 offers high throughput to handle heavy workloads, plus advanced technology to provide confidence in all results.
  • Equivalent results across all ARCHITECT c Systems
  • Identical technology, reagents and assay protocols
  • Identical software that is intuitive to operate
  • Universal ARCHITECT sample carrier
  • SmartWash technology ensures no clinically significant sample tube to tube carryover (less than 0.1 ppm)
  • Robotic Sample Handler (RSH) eliminates bottlenecks and prioritizes urgent requests
  • Immediate STAT processing for fast and consistent turnaround time
  • Up to 65 refrigerated reagent positions plus patented ISE (Na+, K+, and Cl-)
  • 215 sample load capacity including 35 priority positions
  • Continuous sample access
  • Throughput of up to 1,800 clinical chemistry tests per hour
  • FlexRate methodology extends linearities and avoids repeats
  • Integrated Chip Technology (ICT) delivers ISE (Na+, K+, and Cl-) analysis with minimal maintenance, low sample volume (15 uL), and within run precision of 1% or less
  • Liquid level sensing combined with pressure differential technology for enhanced bubble and clot detection monitors sample integrity
Height48 in
Sample Capacity215
Throughput1800 samples/hr
Length 49 in
Weight1545 lbs
Sample TypesSerum, Plasma, Urine, CSF
Sample Volume1 to 35 µL
Width79 in
[list]        Sample Types: Serum, Plasma, Urine, CSF        Sample Tubes:        > Height: 72-102 mm         > Diameter: 9.6-16.1 mm        Sample Result Storage: 50,000        Reagent Type: >95% Liquid ready-to-use        Water Requirements: Deionized Water; ?54 liters/hour        [/list]
