Roche - Cobas Mira Plus
by Roche
Roche Cobas Mira Plus is an open random access chemistry analyzer.
It is manufactured by Roche Diagnostic Systems with a throughput capacity of 144 tests per hour. It produces routine profiles, special chemistries, electrolytes, TDMs and drugs of abuse. The system is known for its flexibility, convenience, reliability and versatility.
-Clinton
9 years ago
Error messages on start up
What could be the cause of the following error messages - touch error; Y-motor init not possible; 144 motor-ctrl II hardware- error; 74 motor-ctrl II over cur.: PIP
-Dr Holland
10 years ago
Serum Ammonia
Can serum ammonia be run on Cobas Mira Plus
  • STAT testing capability
  • End point assay method
  • Variable rack system for calibrators, reagents, samples and quality control material
  • Closed primary tube sampling
  • Direct sampling capability
  • Photometric colorimetric optical system
Height26 in
Length 23 in
Weight197 lbs
Width29 in
