Abbott - Cell-Dyn 3000
Hematology analyzer
The two versions of Abbott Cell Dyn 3000 are Cell Dyn 3000SL System and Cell Dyn 3000CS System. The former features a separate Sample Loader Module whereas the latter one is with a built-in manual Closed Sample Aspiration Module. Abbott Cell Dyn 3000 has a throughput of 110 CBCs per hour and the capability to measure parameters including WBC, RBC, Hgb, Hct, MCV, MCH, MCHC, PLT, MPV, RDW, M%, M#, G%, G#, E%, E#, L%, L#, B%, and B#. This analyzer with S150 open and 250 closed options has standard features such as closed tube sampling, RS 232 Interface, hydrodynamic focusing Leukoprotective reagent, 5 part differential, histograms and scatterplots.
0Replies8 years ago | Can not start. Device is used, and when its arrived its not start: werw many issues with PC (was replaced mainboard, power supply, etc) and at least its displaed "Bad checsum in non-volatile RAM", also the status on embedded indicator is "6" and it does not any mechanical move. The indicator "Ready-Busy-Fault" also not lights in any way. Need any service documentation or some solution of this truble. Reply |
0Replies11 years ago | precio
necesito comprar Reply |
- Easy to Operate - User Friendly.
- VGA Color Display with full Keyboard.Patient name & comments on report. Proven accuracy and reliability.
- 60 CBC's per hour maximum.
- 22 Parameters.
- 5 Part Differential with counts and percents.
- WBC Scattergrams, RBC & PLT Histograms on screen and printed on included graphic printer.
- LIS capability including histograms.
- Full PC-compatible computer system with QC, Control Values, Reagent logs, Levy-Jennings charts, Westguard rules, etc.
- All necessary data for compliance on-line.
- Comprehensive diagnostic messages.
Height | 25 in |
Length | 22 in |
Weight | 265 lbs |
Width | 45 in |
