Nellcor - OxiMax N-85
Pulse Oximeter
Whether it's for an emergency situation, bedside monitoring or routine spot-check, the OxiMax™ N-85™ handheld capnograph/pulse oximeter delivers accurate SpO2 and end-tidal CO2 values. This portable monitor contains Nellcor'™s latest OxiMax™ pulse oximetry and is compatible with OxiMax™ sensors. The N-85™ monitor also features patented Microstream® CO2 technology and breath sampling accessories from Oridion to ensure smooth operation, even in high humidity environments. For capnography monitoring only, Nellcor™ offers the NPB-70 handheld capnograph.
FORUMSView All (7)
1Reply4 years ago | Service I sent this unit out for service and the technician stated that he could not get the ETCO2 to operate despite cleaning the unit. Any ideas on why it may not be functioning?Reply |
0Replies5 years ago | need helping printing data from the pulse ox to either to a computer or a printer I have the communication adapters for the n-85 series and I'm still very confused on how to receive data from the unit to a computer. The user manual does not explain in very good detail how to transfer data Reply |
2Replies5 years ago | Need operator's manual for N-85 Nellcor Need to calibrate a Nellcor N-85. Could not find it in the service manual, thinking it could be in the operators manual.Reply |
SERVICE COMPANIESView All Pulse Oximeter Companies
- Full-featured capnography previously available only in much larger monitors.
- Innovative optical bench enhances stable, accurate measurements from a small sample.
- Low sample flow rate of 50 mL/min allows monitoring on wide patient range without compromising response time.
- Intubated or nonintubated ETCO2 monitoring for neonatal through adult patients.
- Capnographic waveforms and trends.
- Nellcor OxiMax™ pulse oximetry with advanced signal processing technology for accurate, reliable SpO2 and pulse rate readings even during low perfusion, patient motion and other forms of signal interference.
- SpO2 graphical trends and plethysmographic waveform.
- Weighs less than two pounds.
- AC and battery operation.
- User-adjustable alarms.
- Four-language menu.
- Data output/printing, including nurse call and Oxinet™ III central station and paging system.
Height | 8.11 in |
Length | 2.06 in |
Pulse Rate Range | 20-250 BPM |
Weight | 1.87 lbs |
SpO2 Range | 0-100% |
Width | 3.46 in |
- Dimensions: 8.11" H x 3.46" W x 2.06" D
- Displayed Parameters: CO2 and plethysmographic waveforms, ETCO2, SpO2, pulse rate, respiration rate, trend data.
- Display Range: 0-99 mm Hg (0-13.2 kPa and 0-13 vol% at sea level)
- Sampling Rate: 50 +- 7.5 mL/min
- Warm-Up Time: 30 seconds typical, reaches steady-state accuracy 20 minutes after power up.
- Accuracy: 0-38 mm Hg +-2 mm Hg, 39-99mm Hg +-5% of reading.
- Respiration Rate: 0-150 breaths/minute.
- Battery Type: Rechargeable NiMH.
- Battery Capacity: 4-7 hours. Recharges in approximately 4.5 hours.
